Just gettin into my td04 conversion and having to spin the turbo in every direction to get it to fit, ive just taken the inside compresser out of the intake housing by taking a f*** of a pain in the arse surclip out and ive found a tiny little pin does this matter if the pin does not go back in so i can swivel it ????
just remove the locating pin think i just used a pair of pliers and pulled it out
do remove both ?? its has one were spilt you turbo and one were you remove the compresser wheel
I removed both, cant remember if i had to or not, but i did and its all good!
Cheers mate much appreciated
remove both mate :thumbsup: on mine i had to gind one of and pull other out
yeah you gotta rotate both halfs of the turbo and yeah knock both pins out
to get the pins out i used a small screwdriver and hit it a couple times and then used pliars and it pulled out easy peasy took me 2 mins
