omex shift light help plz
omex wiring diagrams
Distributorless Systems - Use the tachometer output from the ECU, or one of the coil
negative connections. For dual coil vehicles ALWAYS set the number of cylinders to two.
RED WIRE Connect this to the coil positive (+) terminal. If this is not easily accessible
then this wire can be connected to any positive feed that is switched by
the ignition switch.
told ya ;) :lol:
told ya ;) :lol:
Thanks very much mate, Would you know the pin-out number by any chance if its no trouble, Thanks
