would an optional rear splitter from a glanza fit on an n/a? i know the bumpers are slightly different but are they different enought to cause this not to fit an n/a?
any suggestions?
keirz
I think they would fit with slight mods.
The optional lip goes inwards from the centre, if you cut that part out of your bumper so it doesn't get in the way, i think it'd fit nicely!
Hope that helps!
cheers, i will have to try and get a closer look to see if it will be easy enough. will also have to look at getting it sprayed as well.
Easier said than done Idrees, the Starlet green is a bitch to get right as has loads of metallic flake and is nigh impossible to match up without being mixed and done by a pro.
(as far as I know)
you are spot on mikey. the starlet green has a blue flip in certain lights, so is near impossible to get it right, even the pros struggled on my bump strips, they are spot on colour wise but in certain lights they dont flip to the blue. plus me and spraying do not get along, im to impatient!
On the plus side though, is an absolutely awesome colour when you get it in good sunlight, looks stunning, but not so good for when doing bodywork parts... :(
i did the same today mate. full green t-cut, then autoglym super resin polish, then a coat of autoglym perfect gloss finish. well worth the effort.
