hkturbo Posted October 1, 2011 Share Posted October 1, 2011 i was changing the gasket when i literally got to the last screw on the cover. as i tightened it it broke off. now i have air leaking through it. what do i do???? will the rocker cover come off if i unscrew the other 4 screws? n where do i find a replacement screw?? helppppp me Quote Link to post Share on other sites
k1r4n Posted October 2, 2011 Share Posted October 2, 2011 i did the same thing last month, put some silicone on a 5p coin and cover up the hole, then get on the phone with toyota and order a new bolt. and yes undoing the other 4 will release the rocker cover hope that helps you i was changing the gasket when i literally got to the last screw on the cover. as i tightened it it broke off. now i have air leaking through it. what do i do???? will the rocker cover come off if i unscrew the other 4 screws? n where do i find a replacement screw?? helppppp me Quote Link to post Share on other sites
hill_bill10 Posted October 3, 2011 Share Posted October 3, 2011 i did this a while back, just nipped down to local scrappers and grabbed one off a starlet down there. it shouldnt be to much to worry about. just get it sorted asap. Quote Link to post Share on other sites
