just dropped my 5E in and it runs perfect apart from it idles around 2000rpm wen up to temp.
i have checked for any air leaks and cant find any, have also wound the adjustment screw all the way in and still no luck
wat else could cause this?
Get a starting fluid can and carefully spray around intake. If it picks up revs, it has a leak. Then do it again but more localy (i.e. tb, intake manifold, etc).
Also, get the adj. screw out and clean it.
