HELLO
I have come to upgrade my turbo on my ep91 to a ct9 hybrid and also decided to fit a hks actuator i will be also fitting a fmic and a zisco ram horn style manifold please can someone give me some advice on how you fit the actuator and plumb it all in etc as im not to sure on how it works
  • 2 weeks later...
bolt it in place where the old one was, i assume you figured that bit but hey you never know. Best way to do the pipe work is to just run off the actuator nipple directly to the nipple on the turbo . You loose hi and low option but who cares! In terms of setting it up, wind out the arm so the hole is just short of the wastegate arm on turbo then pull it on the extra few mil. Take it out and see what she is boosting. If its too low, undo it from the wastegate arm (will be hot so maybe leave to cool down) and make the actuator arm shorter by a few turns then repeat
