DaveyDemolition Posted October 6, 2011 Posted October 6, 2011 Took my door trims off the other day but cant for the lift of me get the glue off the body work, ive tried everything going that wont damage the paint, paint cleaner, t-cut, and bug/tar remover, ive let it soak and then tried scraping it off with my fingernail or a credit card and its just not coming off, what methods have you used? Quote
steviet Posted October 6, 2011 Posted October 6, 2011 I used Autoglum tar remover,let it soak for a bit,or use a hair dryer for a bit of heat.stevie Quote
DaveyDemolition Posted October 6, 2011 Author Posted October 6, 2011 I used Autoglum tar remover,let it soak for a bit,or use a hair dryer for a bit of heat.stevieyeah ive been out on it today with a hairdryer for half hour or so, but ill give it another go with the autoglym stuff anyway! thanks Quote
Amjad Posted October 6, 2011 Posted October 6, 2011 You need to use bug/tar remover, let it sit and heat it up, it kinda goes soft then you can get it offOther option is this:http://www.ebay.co.uk/itm/STRIPE-REMOVAL-W...0e#ht_973wt_932 Quote
