The FD is taller not shorter, in which case the info on the front page of the 4-paw section regarding FD and top speed would be incorrect.
ep85 first gear is silly, you have to rev it right out just to get going lol. i wish i had the gt 1st in mine like WeeJohn
How hard is it to swap 1st gear, I would prefer something taller?
Its possibly mine that is mixed up, I just copied and pasted it from old stuff I have saved.
You need to strip the box right down as 1st is at the end of the shaft. Its a straight swap but once you are there.
From the info I've found the FD would appear to be 3.7. 3.7 is taller then 4.3, shorter the gear bigger the number.
Did you do it yourself or someone else, If someone else done it could you pm me the price if you don't mind? cheers
