sosolid Posted October 19, 2011 Posted October 19, 2011 I need to know if i install a HKS actuator on my 100 percent original glanza how much boost can i get if the engine is 100 percent factory set? Quote
Matt1878 Posted October 19, 2011 Posted October 19, 2011 I probably wouldn't advise that you go turning the boost up without any supporting mods. Just increases the chance of something cracking or going boom!.No need to rush for big boost levels, its not worth the risk of a kapow'd engine. Quote
miib14 Posted October 19, 2011 Posted October 19, 2011 if you up the boost, the max you can is 0.8 because you will hit fuel cut Quote
hkturbo Posted October 23, 2011 Posted October 23, 2011 dont up the boost on a standard spec, your just looking for problems. u cud port the manifold and then run up to a bar but u need to stop fuel cut. Quote
