Azz Posted October 25, 2011 Share Posted October 25, 2011 Can you go ahead and just fit a boost controller or do you need air/fuel ratio management??will it not over fuel if you cut the boost down ? Quote Link to post Share on other sites
corofin12345 Posted October 25, 2011 Share Posted October 25, 2011 nope wont effect anything like that unless your not running the correct mods for the boost you want.. set the high setting to the setting/boost your car is running on now and whatever you want then for the low setting Quote Link to post Share on other sites
