so i have a big turbo now with no compressor nipple. was going to get a tap and die set of a friend adn pop a nipple before throttlebody. as i read if its after throttle body to ext w'g it may rip the diaphragm when off boost due to vacuum? anyway tial sport site to me says do it off the mani. any others running ebc this way? cheers
http://www.tialmedia.com/documents/w3_tial_wginstall.pdf
The tial site is saying take a feed before the throttle body when you read it and look at the picture which would be the same as taking it from the turbo like you are suggesting. The 90 bent pipe on top of the throttle body is just before it have used that in the past.
cheers mate so the little bent pipe on manifold. where does it go as standard as mines hooked up still. can i just unplug it and pop my vac hose on or do i need to t piece things etc
as i was gonna t piece from the bent pipe to wg and controller. thanks
