jamesglanza Posted November 16, 2011 Posted November 16, 2011 Hi need help with fitting an hks speed limit defencer.I have a SLD and on the back it has the code (SLN1-00241)will this fit an EP91 glanza and has any one got a wiring diagram!I no where the red power and black earth wires go but i need help in locating the speed sensor wire on the ep91 ecu and which way round the yellow and white wires go to the direction of the speed sensor and ecu? if this makes sence.Any help is greatly appreciated,Thanks, James. Quote
_shaun_ Posted November 16, 2011 Posted November 16, 2011 cant comment much on the sld but am sure a quik google browse should help you the pin out diagram for the ep91 might be of some help. i presume it will be speed signal u will have to tap into which is pin 11 on the smallest plug Quote
_shaun_ Posted November 16, 2011 Posted November 16, 2011 had a quik look since am bored. as the obv would state red goes to positve black goes to negitive. then u tap in to the 11th pin on the smallest plug ( see above table) the yellow wire then connects to the ecu side and the white wire connects to the loom side. Quote
jamesglanza Posted November 16, 2011 Author Posted November 16, 2011 Top man, will give this a go.Thanks. Quote
jamesglanza Posted November 16, 2011 Author Posted November 16, 2011 Can any one back this up before i go cutting wires!Thanks. Quote
