A L 3 X Posted November 17, 2011 Posted November 17, 2011 I have a cone filter fitted to the standard inlet pipes, basically just sat where the airbox used to be for now until I get a better setup, engine is otherwise standard apart from boost restriction removed, ive noticed on idle if i listen in close I can hear a very faint bu-bu-bu-bu burbling type noise form the filter, is this normal or what? You cant even hear it from in the car with the radio/fan on or when driving its that quiet. Quote
LukeSR Posted November 17, 2011 Posted November 17, 2011 Sure its not just the sound of it sucking in air..? Quote
A L 3 X Posted November 17, 2011 Author Posted November 17, 2011 Probably is tbh, just weird how it does it like a burble? Maybe sumert to do with the fact its FI and not NA?Also, another question lol, i've noticed my cambelt cover to the cam cover has a bit of a gap, is this normal or should there be a gasket or something, or if not does it matter at all? Quote
Nads Posted November 18, 2011 Posted November 18, 2011 Not sure on the noise without actually hearing it.For the cambelt cover, it doesn't matter if there is a cap.I run without the cover! Quote
A L 3 X Posted November 18, 2011 Author Posted November 18, 2011 Its probably too faint to even pick up on a camera recording lol....And ah i see, fair enough then, cheers Quote
