mattyD Posted December 9, 2011 Posted December 9, 2011 what do you guys think?took my car in to have the quaife fitted and and found out that the diff i had in there had a 6 bolt final drive, which after doing a bit of research meant that i (for some reason) had an n/a box on my glanza :Sthe question is, would the 8 bolt quaife be fine to just bolt to a glanza final drive and stick back in the box???? Quote
Taggy Posted December 9, 2011 Posted December 9, 2011 I have seen this posted before on TGTT, your right in saying the bolt pattern is different on the N/A compared to the turbo version. So you mean just get another 8 bolt final drive gear ring and then put the quaiffe onto that and back in the box?I cant see why it wouldnt, but i guess you wont know until you compare it ;)I have got detailed pics of fitting my quaiffe, you can check my final drive gear and compare ;)http://www.toyotagtturbo.com/forums/showth...rket-Quaife-LSDI put that together, hope it will help you compare the two.Craigwhat do you guys think?took my car in to have the quaife fitted and and found out that the diff i had in there had a 6 bolt final drive, which after doing a bit of research meant that i (for some reason) had an n/a box on my glanza :Sthe question is, would the 8 bolt quaife be fine to just bolt to a glanza final drive and stick back in the box???? Quote
mattyD Posted December 10, 2011 Author Posted December 10, 2011 lol, i think it was me that posted the topic over on TTGT aswell bud ;)i found out that due to me having the 6 bolt pattern, it could either be an N/A box or one from the early gt's!the mechanic who has my car had a glanza final drive lying about, so bolted this to the diff and managed to put the gearbox back together ;)hasnt test driven it yet as im waiting for my flywheel to turn up but seeing as though the box is back together, i cant see it being much of a problem really the dicovery possibly helps the n/a owners out knowing that in order to have an lsd, all they would need do is get an 8 bolt final drive with the same amount of teeth as there original and bolt it to an aftermarket lsd will find out for definite after the test drive but it might be possible Quote
earney Posted December 23, 2011 Posted December 23, 2011 excuse my lack of mechanical knowledge but im looking to fit a quaife lsd to my ep91 which i undersdtand is referred to as the n/a. what is this 8 bolt final drive you talk of? Quote
mattyD Posted December 23, 2011 Author Posted December 23, 2011 ep91 is just the chassis code mate, do you have a turbo? if not the final drive (which is basically a cog with bolt holes) in your box i am assuming will only have the 6 bolts like mine instead of the 8 you need to be able to fit the quaifedoes that make sense? lol Quote
earney Posted December 24, 2011 Posted December 24, 2011 yeah its non turbo. where did you end up getting the 8 bolt pattern drive? Quote
Taggy Posted December 24, 2011 Posted December 24, 2011 Hi Earney sorry when i said N/A earlier i was just reffering to a "normaly aspirated" which means non turbo cars, sorry to confuse you yeah its non turbo. where did you end up getting the 8 bolt pattern drive? Quote
