Right, I've had a discussion with my Dad about changing the front end of my car to the EP82 front , But apparently with the EP80 you have to cut out parts to get lights to fit etc, Is this true?
Any help would be appreciated
Jack.
Sweet! :)
Do you know if it's a straight forward job to change the front end to a mk1 then? like just bolt straight on?
Cheers Dale, looking at keeping the single headlight, just wondered what is involoved??
Looking to convert to a MK1 GT front end and which bits he will need.
John
well for just the front end u will need bumper,square lights grille,bonnet,u will also need the small arch lips for the wings then doors under skirts rear panels rear arch lips and u have urself an ep82 ;)
although it sounds like your off for the mk1 front end a quadlight conversion is a pretty easy job. people get put off cause they hear the chopping bit and think no way but its really quite easy and simple.......plus quads do look a lot better than squares in my opinion lol
just checked grill seems ok nothings damaged. only think is the GT bits been sprayed electric blue but you can have it next time i see you. even if you dont use it good for a spare incase anything ever happens to the grill you have on the car lol
