A L 3 X Posted December 17, 2011 Posted December 17, 2011 a bit of a weird one here....ive noticed sometimes i think if i'm stopped, if i let off the brake pedal and set off...my brake pedal makes a bit of a click noise like its pumped itself or something, i notice it when ive had some amount of steer on but it may be all the time....seems to be when I set off from a standstill though.any idea what it is? Cheers Quote
micky boy Posted December 17, 2011 Posted December 17, 2011 I've got this same problem and it turns out it was my cv joint on the drivers side!! Quote
micky boy Posted December 17, 2011 Posted December 17, 2011 I've got this same problem and it turns out it was my cv joint on the drivers side!!Edit god dam ips error! lol Quote
A L 3 X Posted December 20, 2011 Author Posted December 20, 2011 hmm, i dont think thats mine mate as it don't do it on when cornering on full lock :/Deffo seems to be from the brake pedal its weird? like it pushes back up or something its strange Quote
A L 3 X Posted December 21, 2011 Author Posted December 21, 2011 This doesn't actually just happen on full lock, its mainly when first staring the car form being parked up, ill let the handbrake off then sometimes hold on the brake, put it in gear then when i set off its like it releases the brake fully or something when the click is heard form the pedal? Quote
Glanza AuA Posted December 28, 2011 Posted December 28, 2011 mine does the same thing if you do a push on the brake before starting the car it doesnt make that click sound when you start moving, you should try it Quote
A L 3 X Posted December 28, 2011 Author Posted December 28, 2011 Ah I see, maybe something normal then, i'll try that out :y:Cheers Quote
