Seba Posted December 19, 2011 Posted December 19, 2011 I don't have oil pressure in my Glanza V ;) Which may be the reason ?*Car works normally *I don't find any leaks *Oil level in the normal *While driving I have only 3 bar*at idle I don't have oil pressure Is the reason may be oil filter relocation kit ?Thanks Seba Quote
Burny Posted December 19, 2011 Posted December 19, 2011 I don't have oil pressure in my Glanza V ;) Which may be the reason ?*Car works normally *I don't find any leaks *Oil level in the normal *While driving I have only 3 bar*at idle I don't have oil pressure Is the reason may be oil filter relocation kit ?Thanks SebaMy oil pressure dropped in mine mate turned out the bottom end had gone :/ Quote
Amjad Posted December 20, 2011 Posted December 20, 2011 Check the sender on the sensor for the gauge, mine popped out once and I shat myself thinking engine had gone LOL Quote
Seba Posted December 20, 2011 Author Posted December 20, 2011 Is the oil light on the dash on? If so its probably a pressure problem, if not its probably the gauge, sender or wiring issue but I wouldnt even be starting it but until I found out.I was already driving the car and it drives normally. When i went to garage and the car was lifted up the pressure of the oil went up as well.oem pressure probable is normal because I don't have any warnings on dash clocks. I just ordered new oil pressure gauge sensoras it will not help it Glanza will be for sell ;) Quote
Seba Posted December 21, 2011 Author Posted December 21, 2011 So I also ordered a new oem oil pressure sensor. I will install tomorrow and I will see what happens.I will remove the oil filter relocation kit because it is leaking and can therefore are such fluctuations on the guage.Today, the guage runs OK but when I added gas sharply again started freaking - show 4 bar and go down to 1 - 0 bar and again go up for 3 - 2 bar and so all the time. Quote
Seba Posted December 22, 2011 Author Posted December 22, 2011 Ok I remove this oil filter relocation kit and the oil pressure is normal now.but from time to time falls and rises - so probably is this oil pressure sensor - but I will fixed this in next week.Thank you for all the help I got from all of yous.SebaPlease this topic close. Quote
Amjad Posted December 22, 2011 Posted December 22, 2011 My pressure goes from about 1 bar to 4 bar, so it does sound like it was the sensor/relocation kit related! Quote
Seba Posted December 22, 2011 Author Posted December 22, 2011 My pressure goes from about 1 bar to 4 bar, so it does sound like it was the sensor/relocation kit related!Ok but my pressure was 0 bar to 3 bar max (engine hot) and today I removed this oil filter relocation kit and now I have 2 bar to 4.5 bar (hot engine)so now is normal but better I put new oil guage oil pressure sensor and oem oil pressure sensor. Quote
Amjad Posted December 22, 2011 Posted December 22, 2011 Yeah the pressures all vary a little bit from car to car but the range sounds spot on (You shouldn't have been seeing 0 before) Quote
