tom_1593 Posted December 20, 2011 Posted December 20, 2011 im rotating my td04 and ive rotated it so that the oil return points down, do i now need to undo the big circlip and rotate that bit another 90 degrees? im confused??!!! Quote
micky boy Posted December 20, 2011 Posted December 20, 2011 Yeah aslong as the oil return is pointing down sould be all good and yeah undo the circip and it should rotate ;) Quote
Lee_EP82 Posted December 20, 2011 Posted December 20, 2011 Was about 2 years ago i did mine, but yer you rotate so the oil return points down. Then fight to get the big circlip off and rotate the compressor housing so it faces down also. Quote
