was a chattering/humming coming from car when driving but when clutch was dipped noise stopped, so am i right in thinking its the release bearing?
took gbox off this morning and didnt feel too bad tbh, anything else worth checking whilst its off?
ta
previous owner did the clutch less than 5000miles ago though, which is what im a bit worried about.
il replace the bearing first as its not too big a job to take it all off. any ideas where to get one?
Sounds like the input shaft bearing, if it was the release bearing it would grind when you press the clutch, if the noise is there when the clutch is depressed its the input shaft bearing. Have a wiggle of the input shaft and see if theres any play
D
its there when driving but when you put the clutch in it goes away. il check tomorrow as its howling a gale outside now!
