woodchopper87 Posted April 24, 2007 Posted April 24, 2007 exactly what it says on the tinhow hard is it to remove the n/s driveshafta how2guide would be greatly appreciatedcheers Quote
NeilH Posted April 24, 2007 Posted April 24, 2007 bar it out of the box, dont be scared of it. just use something like the flat end of a crow bar, and praise it. hub end....well...in theory you should be able to undo the hub nut and tap it out, btu i have failed on many occasions with my starlets. Quote
woodchopper87 Posted April 24, 2007 Author Posted April 24, 2007 is that the gearbox side ??when you say bar it out of the box i take it just slots in as i dont see any bolts holding the drivshaft box side Quote
NeilH Posted April 24, 2007 Posted April 24, 2007 yes it does just slot in. as i said, use a longish bar with a flat end, and bar it VERY quickly to shock it. it will pop straight out. wheel hub side is a different kettle of fish. spend about half hour on it and if it dont move then it is never gonna come out. so you will have to undo the ball joint, track rod and hub carrier bolts and remove the shaft with the whole hub attached. Quote
woodchopper87 Posted April 24, 2007 Author Posted April 24, 2007 so you will have to undo the ball joint, track rod and hub carrier bolts and remove the shaft with the whole hub attached.wow sounds like fun ?? not lolif that does happen to me how am i meant to tget the shaft out then once i remove the whole hub with shaft ??do i just chap it out ? Quote
NeilH Posted April 24, 2007 Posted April 24, 2007 take it to a garage and get it pressed out. thats is the easiest way.what i did once was stack some breeze blocks up in 2 rows far enough apart and high enough for the driveshaft to hang and then twatted it like a cunt with a copper hammer. if you do that only use a copper faced hammer and watch the wheel studs. Quote
paul w Posted April 24, 2007 Posted April 24, 2007 Theres gonna be a nice big oil slick on your driveway if you pop it outa the gearbox though might wanna have sumthin to catch the oil in. Quote
