do u mean the 2 studs that hold the tmic pipe in place? if so tap a larger thread in and get some longer bolts from your local hardwear shop, or just drill both the holes out and get some long bolts with nuts
you can get 2 bolts from the hard ware u dont have to re tap, tighten 2 nuts on the old stud and undo the first 1, the stud should thread out with them, stick the bolts in, there u go, am not sure of the size, i done this wee job the other day
