Hey guys,
As some of you have seen i bought a quaddie, Now ive fixed the head, leaky oil turbo feed etc etc!
Now,
I have MASSES of blue smoke coming out of the exhaust and a 1500rpm idle speed.
Now obvious culprits, turbo, and rings. But the turbo should be brand new and ive primed it etc. And the rings dont usually produce a proper stream of blue smoke?
BUT, could a broken PCV valve be the cause of this? are there is MASSIVE mounts of blue/white smoke coming out.
I think it might be slightly over filled with oil so im going to let it settle and check it again and drain some out if needs be.
Any other ideas? Gonna be seriously annoyed if its the turbo...
Over filling it with oil will straight away be the first problem but depending on how long the turbo was leaking before and still driven, could be mixture of unburnt oil and moisture where you had manifold off when you was doing the head?
