DaveyDemolition Posted February 19, 2012 Share Posted February 19, 2012 basicly messing around with the lights behind the dash, the ones that light up all the heating instruments... and i cut the wires because i was going to join LED's to them but basicly something happened and now my lights dont work. nothing works, the full beam dipped or high beam and theres no lights on my dash. if it is a fuse then can you please let me know where the fuse is in the car and what amp i need. ive looked on the fuse box in the engine bay and cant see which fuse it is. someone please help because ive got work at 11.30 untill later and ill need to drive home and i cant drive home without any lights i work in a supermarket so i should be able to get hold of fuses etc during the day. Quote Link to post Share on other sites
shavnh Posted February 19, 2012 Share Posted February 19, 2012 Should be a fuse in the dash bit, couldn't tell u which 1 or wat amp best to just pull 1 out at a time and you will soon find it Quote Link to post Share on other sites
5T4R7ET N/A Posted February 19, 2012 Share Posted February 19, 2012 as above the fuse is under the steering wheel, its part of the plastic that the speaker screws on to. Quote Link to post Share on other sites
