mork Posted February 20, 2012 Posted February 20, 2012 Has anyone ever found a metal pcv valve to replace the crappy and expensive oem one? I've found some online but they're screw in ones. But I'm thinking that an adaptor could be made to fit the cam cover (with minor mods), and a metal one screwed in. Quote
WallaceGlanza Posted February 21, 2012 Posted February 21, 2012 Has anyone ever found a metal pcv valve to replace the crappy and expensive oem one? I've found some online but they're screw in ones. But I'm thinking that an adaptor could be made to fit the cam cover (with minor mods), and a metal one screwed in.Any pcv valve will work, I welded a fitting to the cam cover and used an inline pcv valve for a daewoo. Something like this would do: http://www.ebay.co.u...=item519d683d66As you say it is much cheaper than a 30 quid one from toyota! Quote
