You can there's nothing really to say that u cant but it will probably shorten the lifespan of your manifold quite dramatically up to you weather you think it's worth doin mate :D
not worth the bother then i guess cheers
ah get it braced lad :p otherwise you will be taking it off quicker than you put it on :p
manifold is braced decat isn't... have to look at getting it done
personally don't believe heat wrap has much effect on whether a mani cracks or not. quality and grade of stainless, quality of welds, flange thickness, braced or not etc makes more difference if you ask me.
bring on the comments saying how wrong i am! :)
Yea but toysports manifolds aren't the best quality out there tbf and the excessive heat kept in because of the heat wrap will cause it to crack faster that's y I would suggest getting a mild steal manifold if you are wanting to heat wrap as the are much stronger :D
  • 2 months later...
