CLARKYTRD Posted February 22, 2012 Posted February 22, 2012 Hi Folks,I really need x2 Snap Rings, they are on the end of each driveshaft just where the CV joint slots over.Anyone breaking a starlet that might have two for me?Thanks,John
CLARKYTRD Posted February 22, 2012 Author Posted February 22, 2012 Only do the complete shaft, bit silly if you ask me but sure that's Toyota!x2 silly little snap rings is all I need!
james@cjperformance Posted February 22, 2012 Posted February 22, 2012 they are circlips iirc, you should be able to get the righ size in any reputable garage, would cost you pennies also take the shaft with you
rob_bower Posted February 22, 2012 Posted February 22, 2012 Yea there only a 20mm ish circlip better off with new ones anyway they usually bend when you take them Off as I found the other day.
