VICKERS Posted February 25, 2012 Posted February 25, 2012 Just wondering if anyone knows if i fit a decat on the glanza, will it still run ok? Or will i be fuel cutting? Quote
funny onion Posted February 25, 2012 Posted February 25, 2012 depend what else you've done- standard mani? full exhaust system? intercooler? air filter relocation? Quote
VICKERS Posted February 25, 2012 Author Posted February 25, 2012 Cat back , and air filter thats it:) Quote
funny onion Posted February 25, 2012 Posted February 25, 2012 you might hit fuel cut, mine used to hit fuel cut all the time. just get a boost gauge in it and keep an eye on the boost and let of if it's creeping towards 0.85 bar (when fuel cut kicks in) Quote
VICKERS Posted February 25, 2012 Author Posted February 25, 2012 I have a boost gauge atm and its reading 1.0 of boost no fuel cut tho Quote
funny onion Posted February 25, 2012 Posted February 25, 2012 do you have a fcd or different ecu? Quote
VICKERS Posted February 25, 2012 Author Posted February 25, 2012 No the car is standard , am wordering if the gauge is out,as it is mechanic.my old ep82 use to cut alot at a bar Quote
funny onion Posted February 25, 2012 Posted February 25, 2012 mine boosted to 0.6, then after about 4000rpm it shot right up to 1.1/1.2 bar before the fuel cut had chance to kick in. standard actuator was buggered. i'd say decat it, worry about fuel cut if and when. it's not a good thing but not the end of the world. Quote
Mat-Richmond Posted February 25, 2012 Posted February 25, 2012 Decatting makes a good difference pal! Well worth doing if you hit fuel cut might be worth getting either ecu, a fcd or adjustable actuator to keep the boost below cut point Quote
VICKERS Posted February 25, 2012 Author Posted February 25, 2012 Yeah mate i think am going to, have you decatted yours? Quote
pick1 Posted February 25, 2012 Posted February 25, 2012 I de-catted mine it was one of the first things I did and ha an exhaust system on it I started to hit fuel cut but if u careful an watch your gauge u can let of before you hit it or while u save up for management or fcd etc Quote
