Taggy Posted February 28, 2012 Posted February 28, 2012 My boost pressure is all over the shop, can anyone offer any reasons why. I am currently using a forge actuator on a TD04 internally gated.It seems if i set the boost to about 0.8bar it remains solid througout the rev range, its when i go higher i start getting this seesawing effect through the rev range, It flys straight to 0.8bar but then slowly increases to what ever bar i set it too as the revs rise, problem with this is that i have to set the initial boost pressure lower as it increases.Its not boost creep in case anyone thinks so as its a TD04 running fairly low boost so its not an issue.Have a look at this graph to show what i mean, notice how the boost on the first run in red is steady at 0.8 bar, but when we increase it to 1.0bar in blue its not consitant at all.Look at in blue i am not getting peak boost until nearly 6000rpm it seems to go flat for 2000rpm then start rising again, its werid!!I am about to spunk £200 on some EBC management, which i hope fixes it Quote
Taggy Posted February 28, 2012 Author Posted February 28, 2012 Seems i have been having problems with this since i changed to this Forge Actuator shown hereDo you think it could be to do with the spring in it being not up to the mustard, i am having to put shit loads of pretension on the actuator before i hook on the arm to the wastegate in order to maintain a decent boost level. Quote
shorty Posted February 28, 2012 Posted February 28, 2012 I've always found forge gear to be expensive and naff tbh. id run oem actuator and a decent ebc as they help to stabalise boost anyway bud. id also check for any minor boost leaks as at 1bar id of expected abit more than 170hp mate. Quote
Taggy Posted February 28, 2012 Author Posted February 28, 2012 yeah thats 170 at the wheels not the fly Quote
shorty Posted February 28, 2012 Posted February 28, 2012 Ah makes more sense lol so around 210fly. sounds more like it ;) bin off the forge and see how oem with ebc goes dude Quote
