liamg40 Posted March 11, 2012 Posted March 11, 2012 Hello, i`ve started work on my glanza now and need to get it ready for some mods as its pretty much standard at the moment,I`ve noticed a coule of small oil leaks, I`ve located one of them so far (cam seals), I thought the other was leaking from the oil filter but when i stripped the air con out and took the filter off and it looked like it was coming from somewhere above that, i didnt have much time to get an in depth look as it was getting dark by then, (any ideas?),Anyway my question is does any one know where i can get some good quality engine seals from or is it best to get them from the toyota stealership?Thanks in advance, Liam. Quote
akyakapotter Posted March 11, 2012 Posted March 11, 2012 have a look on tuning developments bud but toyota are expensive i had a quote on a gearbox side crank seal and its 0ver £50 Quote
liamg40 Posted March 11, 2012 Author Posted March 11, 2012 have a look on tuning developments bud but toyota are expensive i had a quote on a gearbox side crank seal and its 0ver £50cheers mate, thats a lot of money just for one seal! Quote
akyakapotter Posted March 11, 2012 Posted March 11, 2012 tell me about i i see they have them on tuning developments but un sure if its right Quote
Asad Posted March 11, 2012 Posted March 11, 2012 the gearbox side seal is a big-un, hence the price....get the the full gasket set from toyota it includes everything you need for about £150 odd which is a bargain considering you get the exhaust gaskets too Quote
akyakapotter Posted March 11, 2012 Posted March 11, 2012 is this the right one as its so much cheaper than toyota CLICKY ?? Quote
