Has anyone had experience fitting these or no anyone that has? Have calipers, carriers and disks!
Any info would be great going to look into fitting these in the next week or two
thanks in advance
steve
The Coupe kits we do for the 16vT etc are a different bolt mounting pattern to the Starlet ones - so if you have sliding Coupe calipers on carriers I'm pretty sure they won't fit... (ie, they won't fit if the bolts are 100mm apart)
Only other thing off the top of my head is the Coupe piston area is much larger than the Starlet, which could mess up the bias and/or result in a soft pedal!
Do you have a link to your kits. is there anyway of adjust bias to stop that or is that not possible. not to sure with these atmvlooks like a bit more research may be needed
