m11xky Posted April 2, 2012 Posted April 2, 2012 I am getting the same gear change crunch as many others. Went to check the gearbox i got with the car and the cube looks like this...Same as the others ive seen..But looked on mine with some 'no look' picture taking and mine looks like this!!!!Whats that about??Missing cube???help! Quote
WallaceGlanza Posted April 2, 2012 Posted April 2, 2012 Toyota changed the design on later models.If your gearbox is crunching it will be the synchros that're worn - very common. Quote
m11xky Posted April 2, 2012 Author Posted April 2, 2012 Thanks, didn't realise that!So is that definitely new or refurbished box?Mike Quote
Asad Posted April 2, 2012 Posted April 2, 2012 what year is it? ive only ever seen the metal cube (can be turned over) and the plastic "cap" (cant be turned over).......never seen just a metal stump....interesting Quote
WallaceGlanza Posted April 2, 2012 Posted April 2, 2012 what year is it? ive only ever seen the metal cube (can be turned over) and the plastic "cap" (cant be turned over).......never seen just a metal stump....interesting Actually you're right enough, is the "stump" as Asad put it making contact with the bit which has the wear mark on it, if not then the cube is missing! I didn't look at it properly earlier and it doesn't look like it's making contact. Quote
m11xky Posted April 2, 2012 Author Posted April 2, 2012 I took the cube off the other box i have and tried to put it on. But the stump is too big! must just be the way it is?!Mike Quote
Asad Posted April 2, 2012 Posted April 2, 2012 Must be the way it is then unless someone else can shine some light on it, the "stump" looks fatter so we can assume its the way it is both my na's 96 + 97 had the plastic one Change the gearbox oil to see if it helps, another quick little thing you can before fitting another box....but as above its probably the syncros Quote
