Glanza AuA Posted April 3, 2012 Posted April 3, 2012 (edited) hi guys im about to install a fpr on my stock ct9 glanzaand was wondering at what psi or bar should the fprbe at ?? will be running at 10psi boost max becuase of therestricted mani!!i know the stock ecu can handel most of the boost at 12 psi maxbefore fuelcut..but can i just install this as a engine dress up ?? if so at what psi or bar?this is just temporary before my blitz ecu and tdo4l kit arrives thank you will appreciate all the advice and help Edited April 3, 2012 by angeleau Quote
ro55ifumi Posted April 3, 2012 Posted April 3, 2012 2.3 - 2.4 bar and set it with engine running and no vac line attached to the regulator, you will need to have the afr,s checked to be on the safe sideJohn Quote
