They are an MOT failure unless fitted from factory as they have the headlight washers which is required plus aren't scattering light all over the placve
they can only fail if the beam pattern is wrong, no other reason for failure......headlight washers arent testable unless the car came fitted with them from the factory.....nothing to test so no reason for failure....if they are present and dont work its a fail
i like this they are piaa ones so none of this cheap ebay ones so hoping they are all good lol
the same as asad mentioned, headlight washers are for cars fitted with projctor lense, its all good aslong as pattern is correct and not scattered.
@ potter, when the beam is pointing to the wall can you see straight lines or just a massive blob?
HIDs FTW!!!!
I heard loads of reports of the cheap ebay ones being far better and long lasting than the expensive ones over on corolla forum. got 65pound ones off euro car parts and they were fine on the T-Sport.
Also you can get low beam only for £25 on ebay and they look exactly like my £65 ones. you could buy three sets (dead easy to install if one goes wrong!!) and have two spare sets!
Also it saves on bulbs in long run as they last ages and halfrauds want stupid money for ice-white bulbs!!!
£25 HIDs 4 my Glanza when i get the chance 4 sure!
Mike
