is it just the big cover of the gasket your replacing? if so they are pretty cheap from your local motor factor if your changing them all like spark plug seals they are pretty costly
I was just gonna replace all of them. I will look into how much it will all cost. Can I get the spark plug seals from the same place?
yea the spark plug gaskets are like £12 ech and theres 4 so thats £48 straight away the actual see around the cover you will need to change is under a tenner am pretty sure.
