Lawless Posted April 10, 2012 Posted April 10, 2012 Thinking of buying a set of Rota gt3 15sPcd 4X100Was wondering if these are gonna fit not to sure on the fittings on these cars ? Quote
Fozzie Posted April 10, 2012 Posted April 10, 2012 The PCD is right but it also depends on the offset (et), I think it should be around 35-40 for the Starlet. You'd also want the right size tyres, I think 195/50/15 is probably one of your best bets. I'm sure one of the gurus can confirm these for you though Quote
WallaceGlanza Posted April 10, 2012 Posted April 10, 2012 It's the correct pcd yes, it would be best to also check the offset (and width!). Quote
lilryan Posted April 10, 2012 Posted April 10, 2012 yes they will fitt mate glanza's have an et40 normally but you could get away with a et30 if you had a stiff set up bud Quote
Lawless Posted April 10, 2012 Author Posted April 10, 2012 I'm finding out the width and offset he seems to think they will be fine with a spigot ring to sort out the centre bore but I don't want to buy them and find they don't fit what sort of offset and width would be sensible and not rub ?Thanks Quote
WallaceGlanza Posted April 10, 2012 Posted April 10, 2012 Aslong as you use tapered wheel nuts and the nut seats are tapered (and match the nuts) you don't need spigot rings. Quote
Fozzie Posted April 10, 2012 Posted April 10, 2012 I think you would want 6.5J - 7J, with et35 - 40. You can go further though depending on your suspension setup and tyre size Quote
Lawless Posted April 10, 2012 Author Posted April 10, 2012 I think I'm running 195 50 r15s at the moment on a bog standard suspension Quote
Lawless Posted April 11, 2012 Author Posted April 11, 2012 Offset is et 40 so they should fit well ? Quote
