Hi
I'm about to start the conversion above, however I'm not sure weather I need to change the ecu or would upgrading the injectors and fuel regulator will do the job.
If a 5e-fhe ecu is needed is it as simple as pulg and play or does the loom need to be changed?
Cheers in advance, Chris
The loom has to be changed, Im not sure which bits off each loom you'd need to use as im running a link ecu not the 5e one.
Which version 5efhe do you have? the acis intake one or the one with the standard intake?
I wouldnt be sure without seeing the pinouts of both ecu's. It might just be a case of swapping which pins a few wires go to or a complete re-wire.
If you could get me the part numbers of your 4e and 5e ecu's i might be able to have a look into it for you.
Also good luck with the swap man, its well worth the effort.
