For sale: 4EFTE Block only with Caps
Item Condition: Good
Price and price conditions: 45 quid
Extra Info: Came out of a working engine
Contact Details:
PM me
Swansea
Delivery & Conditions of Delivery:
This is heavy as hell, i would prefer you collected it, if not i can send it at the buyers expense, will be about £18 to post
Edited by Taggy
bump
hi mate , as you read i have a worn piston ring and im thinking just to cover all basis , if my cylinder/cylinders are badly worn i wouldnt say no to a good conditioned block which i would then jus change my rings and put the pistons into the good block , what kind of condition are the cylinder walls in this block like buddy ? and was their any oil burning issues when it was on the running engine before ? also did you get any compression reading at any point when this engine was running ? as im looking to be rebuilding with a td04 i need to ensure the engine is going to be healthy runner so a good block is a must , if you could let me know when you get a chance thanks buddy
  • 2 weeks later...
hello mate do you still have the crank ...dose it come with the bearing caps and cambelt crank pully... whats the lowest you will take posted ???
hi
Yes i still have the crank and I do have a crank pulley you can have in addition to the crank if you want. The caps on the crank will be specefic to the block, so unless you buy the block too i cannot split them as they are machined for that matching block.
With the crank pulley ill do it for £100 plus any postage charges.
  • 2 weeks later...
  • 5 months later...
