Hi
My boost was 0.8 bar
I have turned actuater making less threa show and its still showing 0.8?
And here a pic of when i put it back
Is it proper where it clipped on to the hook thing or do i have to make that hook thing on the right its at top at the moment if that makes sense
Cheers
ok in that case id say its to high you need take the vac pipe off undo the lock nut at the top of it and wind it out till its at 3.1 bar with the vac pipe off then tighten the lock nut back up and put the vac pipe back on like i said before id get it rr a.s.a.p mate any one else got any views seams to only be me at the moment ?
