Billy SR Posted April 23, 2012 Posted April 23, 2012 Okay, so I recently changed my headlight bulbs to Osram Nightbreakers and my indicator bulbs to Osram Diadem's.I had to rip the rubber around the headlight bulbs to get them out as it was stuck.I also changed my numberplate lights to phillips blue vision. I also had a brake light out, so I used a bulb left over from the indicator and put it in place. All was fine and dandy and everything was perfect, then suddenly.The centre brake light started being jammed, so i've taken that bulb out as other people would think i'm constantly braking, but now my brake lights and tail lights aren't even working.The only light i'm getting from the rear is the driving light which works when I press the brake pedal with the car turned off now, nothing did light up before? I have no blown fuses, so I can't seem to figure out what is causing my lights to bugger up? Quote
BoGlE Posted April 23, 2012 Posted April 23, 2012 If you havnt messed with any wires ide change you brake light switch. Its connected to the top of your brake pedal under the dash. Should be pretty cheap to replace Quote
ryan lang Posted April 23, 2012 Posted April 23, 2012 have you used dual fillament bulbs for the rear clusters and single fillament for the centre brake light? Quote
Billy SR Posted April 23, 2012 Author Posted April 23, 2012 got a feeling that's the problem ryan, but i'm gonna check bothyay everything in my life is simply going wrong this week. was a reliable car until now Quote
ryan lang Posted April 23, 2012 Posted April 23, 2012 haha they are until you mess with them mine was the same Quote
