Rossi_Glanza Posted April 24, 2012 Posted April 24, 2012 I am going to be converting my Glanza to a manual soon, i know that there are a few wiring mods that need to be done.Something to stop the ignition barrel locking the key in?Extend the reverse wires?Bridge out a plug on the gearbox?I need to know what plug and wires need bridging out on the box and how to stop the ignition barrel lock. Quote
mrkd5916 Posted April 27, 2012 Posted April 27, 2012 something to stop the keys being locked in is a punch and a hammer as you can carefully bend the care to stop the lock from moving,bridging out the plug on the gearbox. it the two wires that are on the top, as you look at the plug your see that there are two thicker wires, they are the ones that will need cutting and joining togetter,if you get stuck give us a shout and i try to halp as much as poss,cheers, Quote
Rossi_Glanza Posted May 2, 2012 Author Posted May 2, 2012 Thanks mate. Will do that soon. Any other mods need doing other than the ones mentioned above sensers? Quote
