Pros and Cons of Removing ABS from a high powered starlet?
Could someone explain whats involved in removing abs for me please :D
This is everything that comes out.
Disconnected the metal brake lines that connect to the rubber flexi pipes or braided should you have them, then disconnect the hard pipe from abs to flexi pipe roughly 6" long on both ns and os, disconnect both brake lines that run off the master cylinder, disconnect both rear brake lines from the bottom of the p valve located on the bottom of the bulk head, unplug the actuator and remove the relay, undo the 2 12mm bolts on top and one underneath and then it all pulls straight out. Leave your master cylinder on though.
I replaced all the above with standard uk spec starlet front brake lines and it was all a direct fit.
Hope this helps lol would of been easier with pictures. I preferred to doing it this way as it was easier than making the brake lines lol plug and play option.
