Got a couple of problems with my glanza at the moment. One is that I noticed an awful lot of CV grease in my driver side wheel and it appears that the rubber boot has caught on the bottom of my coilovers (had them quite low but I thought it was clear of the boot.) Is this a simple case of replacing the boot and regreasing the joint or a whole new joint? There is no noticeable tear or hole so it might be clear of debris?
Also when motorway cruising my 5th gear will spontaneously jump out of gear (4th sometimes too). Would this be the syncros? (I have a spare gearbox just in case as was planning an lsd. Would it be an easy enough fix if I was to swap the boxes over?
