Fitted indiglo dials at the weekend and since then i have noticed at ignition my airbag light is not illuminating any more. Its not the bulb as i changed that over with a working 1 to try it.
What puzzles me is the light is there to indicate a fault in the airbag system so if its not coming on at all i imagine maybe an earth has come off somenwhere or a fuse is blown?
I changed my speedo over from kph to mph while i was doing this so that has been in and out. Does anyone know if there is earths for the airbag system at the bulkhead in the engine bay?
Or what fuses to check and where they are located as i cant seem to find them? I know its not exactly a big deal but it is safety afterall and im a bit OCD and like to know everything is working perfectly with the car as thats kinda what ive been going for with it.
Cheers
Edited by StuDoc 72
  • 2 months later...
Its is not in the fuse box under the dash or the one in the engine bay?
The airbag ecu is mounted ontop of the channel under the dash, so check that the plugs are in place, check all the screws went back in the back of the clocks as these may supply power to the srs light (assuming they got removed fitting the dials)
