Jordk Posted May 2, 2012 Posted May 2, 2012 (edited) Just got my Depo Wideband gauge and kit from cj performance. When it comes to fitting do I need to get the boss welded onto the decat or the exhaust itself? Also how simple is it to wire in? Does it have to be wired through the ecu?CheersJordan Edited May 2, 2012 by Jordk Quote
turbo Grant Posted May 2, 2012 Posted May 2, 2012 Would need the boss welding to you de cat. Dose it not come with a wiring diagram? Quote
james@cjperformance Posted May 2, 2012 Posted May 2, 2012 there is a wiring diagram in the box dude, just wires in like a normal gauge and the sensor bung welded a in the exhaust Quote
mech5107 Posted May 2, 2012 Posted May 2, 2012 Better put the sensor in the exhaust, after the downpipe. It's needed to have some distance from the engine...they don't like the heat very much.I suppose you have a decat-pipe...if not, it won't ready correct. You don't have to wire through the ECU... Quote
Jordk Posted May 2, 2012 Author Posted May 2, 2012 Ok so If I get it welded just after the flange on the exhaust after the decat that would be fine? Quote
