Installing Depo wide band
Just got my Depo Wideband gauge and kit from cj performance. When it comes to fitting do I need to get the boss welded onto the decat or the exhaust itself? Also how simple is it to wire in? Does it have to be wired through the ecu?
Cheers
Jordan
Edited by Jordk
Better put the sensor in the exhaust, after the downpipe. It's needed to have some distance from the engine...they don't like the heat very much.
I suppose you have a decat-pipe...if not, it won't ready correct.
You don't have to wire through the ECU...
