Andykelly Posted May 2, 2012 Posted May 2, 2012 Hi I've had a look and can't see a post already. Which fuse is it that the windows run off? Ive got the diagrams of the fuse layouts from tgtt but it doesn't say on them which the windows is. If anyone could let me know it would be a great help.Thanks Quote
5T4R7ET N/A Posted May 2, 2012 Posted May 2, 2012 you checked the fuses under the steering column yeh? checked if any are fused? Quote
Andykelly Posted May 3, 2012 Author Posted May 3, 2012 Yeah when I got it mot'd the guy said he checked. I don't have anything to check them with. Quote
5T4R7ET N/A Posted May 3, 2012 Posted May 3, 2012 you dont need anyhthing special to check the with, just pull them out and see if they are fused. there is also a fuse box in the engine bay.its on the right hand side were the bonnet support bar is. check them as well. Quote
Andykelly Posted May 5, 2012 Author Posted May 5, 2012 i just changed all the fuses in the engine bay and uder the dash and still the electric windows dont work, and also any of the controls that are on the door. I've had a quick look at the wires and they all seem fine.Would anyone be able to do me a massive favour and take a pic of the fuse boxes so i can double check i have the correct fuses in the right place?And does anybody have any suggestion to what else it could be? Quote
