Valve Seals or Turbo Seals?
The problem is starting to get slightly worse, started off a while back that it would smoke after a long idle period and now it smokes once the power is put back on after lifting off aswell. No smoke at all during normal driving or boosting though and from reading on here i'm pretty sure it's the valve stem seals although I would rather check before changing them as it was only a couple of months ago I changed the manifold and there was no oil.
Smoke had stopped so it went out my mind then coming home from work today and an intercooler pipe blew off and when I checked there was a fair bit of oil sprayed. Put pipe back on and will put more oil in her tonight, could I limp it in and out of work thus week until I get a new turbo? And does anyone know of any for sale? Cheers
