lilryan Posted May 6, 2012 Posted May 6, 2012 ive fitted a sard fuel reg to my car now ive used the braided fuel line thats replaced the orignal pipe that then had the long mental pipe onit that ran along the back of the fuel rail .ive removed that and gone with my braided line from the solid pipe near the back of the gear box to the bottom of the fuel reg it this the right way round cheers pic below Quote
akyakapotter Posted May 6, 2012 Posted May 6, 2012 the one where you have your gauge im sure i have as my feed mate Quote
lilryan Posted May 6, 2012 Author Posted May 6, 2012 yer the two holes are the same mate its just the 1 on the bottom that is different Quote
wssoR Posted May 6, 2012 Posted May 6, 2012 Aslong as the fuel goes into the bottom it doesn't matter which of the side ones it comes out of Quote
lilryan Posted May 6, 2012 Author Posted May 6, 2012 you see where the braided line come's off the solid pipe under the filter then travels up to the bottom of the fuel reg is that how youve got yours mate ? Quote
akyakapotter Posted May 6, 2012 Posted May 6, 2012 yes the bottem one goes back to the return to tank i had it the other way round first and it wouldnt read on the gauge so the way you have it now is right Quote
lilryan Posted May 6, 2012 Author Posted May 6, 2012 does the fuel feed from that pipe where ive got my braided line coming from or is it the pipe at the other end where you put the fuel rail adpotor .but does the fuel have to feed in threw the bottom of the reg ? also what is the line for on the right hand side of the fuel rail if you stood looking at it with the big banjo nut that goes threw it think its a 17mm or somthing Quote
lilryan Posted May 6, 2012 Author Posted May 6, 2012 cool cheers mate just thought to my self earley have i put it on the right way as all the instructions are in jap lol Quote
wssoR Posted May 6, 2012 Posted May 6, 2012 It's fine how you've got It, just to check you didn't buy that fpr off eBay did you? Quote
lilryan Posted May 6, 2012 Author Posted May 6, 2012 yer mate i did its been sealed wit ptfe tape so it wont leak or owt i wanted afuel lap 1 but im on a tight budget and time limet at the min Quote
