kingo228 Posted May 9, 2012 Share Posted May 9, 2012 hi guys , I've had my head skimmed at work and he took 0.114mm off.the block is standard.What thickness is the Stock head gasket ?i will be running higher boost .8 - .9 eventually and is it work getting a 1.2/4mm head gasket Thanks dave Quote Link to post Share on other sites
DevonGT Posted May 9, 2012 Share Posted May 9, 2012 1.2mm unsquashed. Quote Link to post Share on other sites
kingo228 Posted May 9, 2012 Author Share Posted May 9, 2012 so is a stock gasket the same size as a ATHENA 1.2MM ? or is that 1.2 when crushed ? Quote Link to post Share on other sites
starletburkie Posted May 9, 2012 Share Posted May 9, 2012 about 1.0mm the oem is when tourqed up Quote Link to post Share on other sites
Idrees Posted May 9, 2012 Share Posted May 9, 2012 The OEM one will work fine at 1 bar if fitted properly Quote Link to post Share on other sites
