I have all bolts except one out on the old manifold....
How did you guys get the bottom left nut off (engine to manifold)?????!!!! I just cant get in there!
Also, read that the turbo has to slide forward.....how to i get it to do that? cant see what to undo.
Thanks!
Mike
It's a pain in the ass ! When I helped change a friend's mani on his glanza we had to get it from under the car and use a bendy socket adaptor, if I remember correctly :)
Like above take the power steering pump off and you haven't already take the radiator off gives you so much more room :)
think when i did it i had a footlong extension with a socket on the end and was just able to squeeze in, its a pain in the arse and i would be happy if i never had to do one again lol :)
